Trans is out and pumps apart. No obvious indications of why it can’t make spec pressure. Digging deeper
Yes to all of the queries TexasT. The pressure relief check ball looked good but will revalidate nothing got pumped into it on start up.What does the ball under the spring on that pressure relief valve look like? I've seen rusted ones that didn't seal well.
I do think you have too much clearance on the slide if you measured with the seal in place. I guess the pocket is decent and doesn't "catch a fingernail" on the bottom. The vanes in good shape and fit the "new" rotor well. Hard rings top and bottom on the vanes keeping them in position.
I did a shitty job of copying but......Here’s the PR valve train exactly how it came out of the pump.
Ok here you go WE4. The first pic is of the lo/rev boost from the other end. Note that this one does not have the 2 small lines you reference. This is a CK Performance lo/rev boost valve. I did find the old one and show a pic of the two side by side and the measurement difference between the lines as you requested. What other mod did you have in mind?I did a shitty job of copying but......
turn the valve over with the large blue line 180 degrees pic again
Measure the length of the valve with the two tiny lines between the lines.
Where did you get this PR system from? I would also make 1 other mod.
WE4
If you do not understand something contact me.
Ok here you go WE4. The first pic is of the lo/rev boost from the other end. Note that this one does not have the 2 small lines you reference. This is a CK Performance lo/rev boost valve. I did find the old one and show a pic of the two side by side and the measurement difference between the lines as you requested. What other mod did you have in mind?View attachment 342113
No results yet. Surface plate should be here this week. Then i’ll Parallel the pump halves , do some PR valving validation and re install and check pressures again. Might be 1-2 more weeks before I have numbers to post due to other commitments. I’ll keep the group posted.What was the results
