ClassicCars
I was looking around to buy a low mileage '87 Grand National, I came across an original car with approximately 10K original miles with great owner history.
While looking at the partial VIN number stamped into the pad of the engine block and the side of the transmission case, I found that the two numbers matched each other.
"4HP4XXXXX".
Here is my question: Those two stamped numbers that were on the block and trans where one digit off from the car's actual VIN. (VIN tag, RPO Sticker, Window Sticker.)
Example: The last eight digits in the car's VIN are: HP123456, The engine block and trans had: HP123457 (The last digit was incremented by "one".)
It was like there was a problem on the assembly line and pulled one engine/trans setup off the line and took the next engine/trans and kept going.
Did anyone ever seen this or heard of this?
I'm 100% sure this is the "original" power train in the car. Was it "Stamped" wrong or the assembly line's quality control wasn't that good back then??
Thanks for you help, Bill
"4HP4XXXXX".
