vector wheels,wilwood disk brakes,gnx dash
dalton
I have 4 vector wheels that are 15" by 8.5 with pretty decent tires and two that are 15 inch by 7 I believe without tires. Basically like to sell together.A Wilwood disk brake setup with 4 dual piston superlite calipers, 12 inch slotted rotors and mounting for front and back also new brake pads. Fronts are bolted to spindels and included. BO. I also have a gnx style avc dash cluster with cover plate with all vdo gauges thats a plug and play just need oil and water sending units. I'm including some pictures but it was kind of dark in the shop.
The wheels with tires are 15" by 8.5 and i have two without that are 15" by 7 I believe.
Hi,Im still would like to know what the back spacing is on the 15 x 8.5
wheels?,Turn wheel over and measure from back side where the rear
brake drum meets the wheel the distance to the outer edge of the wheel.
Im not the best at explaining things hope you will understand.Please let me know how many inches this is.
Thanks,
John
Are the rotors that are by themselves spares for the front or are they rears and if they are rears how do they mount to the axles? The calibers for the rear do they have a prevision for the ebrake?
Dalton,
3 3/4" is what im looking for.Is the wheel bolt pattern the same as a
stock 1987 Buick GM 8.5 10 bolt rear end?If this is yes i would like to get
2 of your 15 x 8.5 Vector wheels and pay to have them shipped UPS ground
to Zip code 92064.Think about it and let me know how much for 2 of them!
Hope we can work something out.
Thank you,
John
