captflash
Old and Bold
- May 10, 2009
Ive had my T Type for 8 years and drive it quite often. Over the years I've gone through the whole system, from booster to master cylinder to brake lines to pads ect. They worked great and anytime I had an issue I fixed it. Recently I installed a front mount intercooler TA performance headers and a 6870 Precision turbo. Prior to the new parts the brakes worked great. After the parts they are hard. The pedal is hard and I have to lay on the pedal to stop. I've tried backing up adjustment, checked the check valve and it was good. Pulled the check valve out of the booster and there was vacuum. My boost gauge shows 17-18 lbs vacuum and still a hard pedal. Thanks kindly in advance for your suggestions and help.
