Alright I apologize ahead of time if this topic has beat to death but I could not find much information on it doing a search. (perhaps I used wrong key words?)
Is there a big downfall to using an 85 block for a turbo swap?
I ask only because my friend JC93z bought a block thinking that it was an 76-87 block and after further investigation appears to be an 85 block.
The large diffs I can find right now are the lifter valley designs and the lack of a turbo drain back. The turbo drain can be overcome with a drain in the pan.
Only thing I worry about is the stregth of the block. Is the 85 block strong enough to handle the power to make a 10 second motor?? Or is it worth doing more searching for a 109 casting?
I saw that there seemed to be a lot of cars in 86-87 that came with the 109 block which may make finding one a little easier.
Any info you guys can supply us with would be great! Piston, crank, rod compatibility. anything.
