Originaly posted by Lee Thompson:
Guess I'll get back to working with what Ive got. I did ask him if there was a "sweet spot" on the ta33 and he said something about (if running a intercooler or alcohol injection), being able to tune to run up to 28psi. If anyone has any suggestions as to what to focus on to get my mph going up please let me know (lately its been closer to 100). I plan on getting my other block together sometime in the not too distant future, and putting all my stuff back on it. Its .030 over bore/forged pistons and a 204/214 cam (was thinking about getting center billet main caps also). Dont know if with the porting (heads and intake) if adding the larger cam into the mix will give me much of a hp increase or not.
Well, I finally got around to calling Limit Engineering and got some bad news. There is some sort of backing plate that is used to do this conversion? Well it is no longer available, the company that made it went out of business. According to what I was just told on the phone the options for a turbo upgrade are next to nill after the ta33. Yes you can fit the next bigger comp wheel in the 33 (60 I think) but what I was told was that it would only be about a 40hp increase. He beat me to saying that it wasnt enough bang for the buck ($450-$500 for 40hp ). He said the ones (66's) that they did in the past that are out there are the last ones.Send him your stock 87 along with a cone adapter (I have an extra). He will weld the adapter to the 87 compressor housing so you only use 1 o-ring. Ask for a 66mm compressor wheel --a Q trim exhaust wheel with a Precision 85 exhaust housing.
