I've been trying to workout a miss matched combo i bought my car with for a while now. One big question mark is the cam. i've only met one other user with a tta. The rebuild invoice states under the parts section "Ultradyne cam 266 deg. .442lift" then at the bottom it reads "cam specs: lift 471
112 lobe seperation 210 dur.@50.
The closest thing i could find on ultradyne.com is listed in the Buick v6 section as turbocharged performance, specs are:
in/ex
Dur. @50- gross lift - Dur @seat - lobe sep.
221/211 .485/.471 276/266 108 deg.
I've done a lot of searching and its big compared to what most guys have. Right now my car has the stock turbo,ic,injectors. hooker headers and down pipe and a 3" single
it also has a casper ultrachip 8 pos burned for combo. It seems to idle fairly well with a slight lope. lacks lowend but hookers.
I'm was leaning toward putting together a somewhere in the 11's street/strip combo, as of now on the shelf i have a walbro 340M, MSD 50's, and a set of stock headers
what kind of combo would this cam match up with? full race? I know all you guru's hate cam threads but i could use some informed opinions
in/ex
