Turn on led...
Mikeymikesttop
AKA-- mikes86ttop
Hey guys, just finishing up installing razors alky kit... I'm On the final step for checking lights and leaks.. When I hit the test button I get the power injection bulb to light but no turn on led, red or green... Low level light is on as well. I can hear pump run when button is pressed but no light? I have an extra low level led on hand, can I put that in place by any chance to try?.... Thanks Mike
~JM~
Wrinkled Member
Read through the directions & testing procedure again. Seem to recall the red/green happens after pressure is built.
Mikeymikesttop
AKA-- mikes86ttop
Mikeymikesttop
AKA-- mikes86ttop
Step 10. When hitting test button only the power injection light comes on. I get no red turn on led like directions say... I did hook up another led I have and it lit up leading me to a bad turn on led... I contacted Julio earlier, just awaiting response.... I called it a day after this... Thanks Mike
~JM~
Wrinkled Member
Mike,
Any update on this problem? Went through these steps this evening. When I depress the test button my LED illuminates green instead of red.
Mikeymikesttop
AKA-- mikes86ttop
Ended up being a bad led... So yours is going straight to green when you hit the test button? No red at all?... Mike
