Turbo Tweak Street Chip
FastGN007
I know that on the website it says this chip will not pass emissions. I am assuming that some of this is because the EGR is no longer functioning. Has anyone tried to pass an emissions test with this chip and what were the results? Just curious!
Thanks,
Scott
Almost all performance Chips will not pass.
Buy a emissions Chip $20 bucks from Eric
I am going to end up getting an emissions chip from Eric but I was curious how far off people have been. I have passed Maryland emissions tests with no cat and an ATR street chip as well as a Kenne Bell street chip.
Thanks,
Scott
The TT street chip has no EGR and it idles in open loop. That will "usually" prevent it from passing. However, there are a few people that have passed anyway. You can try it and see.
The emissions chip turns the EGR back on, goes back to closed loop idle, and the other usual stuff like higher fan temp, higher idle speed, delayed PE, low boost, etc. All that stuff seems to help out. I don't do anything else special in there. It's very similar to a stock chip.
Regards,
Eric
