Turbo oil drain line
blubaldmontess
Hello all! I'm needing some assistance. Ibtransfer tracked an oil leak down to the turbo oil return line from the turbo to the intake. Whomever owned the car put a rubber house in there instead of the actual hose. So I see you cannot find original ones, what are you guys using, and how do you install it. Thanks for any help, post numbers etc
Lockman
OH, OK .......Now I get it
GBODY . Here's some pics of mine. Cut your Turbo Brace / Bracket or you won't get it done with the turbo on. ( Just Say'n )
Lockman
That's for My '84. They're pretty similar, but they have one for an '86 /'87, too. Oh , & BTW , jerryl has an instruction somewhere on the bracket cut. I believe he invented it . Search it, OK ?
....Richie
"Black Ice"
I'm doing the same thing now, I will post pics later. Is that the drain tube off a '86-'87 u used in ur build?
blubaldmontess
That's what I'm assuming, looking how it slides down and volts into the intake. If people have I want to see how they've done it so I can see because I can't find a stock replacement
Buckshot G/N
I have a NOS / EOM 86/ 87 Turbo drain tube. Not cheap PM if interested.
Lockman
Not sure...... I used a 1" compression fitting barrel on my '84 .
