The Granny
- Sep 30, 2015
Finally got my car ready to test out, and I've got a base tune from Cal. One of the first obvious things I'm seeing on my 93/alky combo is the need to get the VE table more accurate, i believe my first pass in the car it was rich the entire time (O2 Corr. around -10%). I messed with some of the cells a little bit, I didn't want to make too much of a drastic change and rich pulling too much fuel, so I made small subtractions and am ready to test again. I want to reduce the possibility of any knock while I'm trying to dial in my actual a/f to reach its target numbers, so one thing I just thought of doing to help that would be to pull timing. I was thinking about trimming the entire timing table 10-20% to achieve this, but I am unsure if the method I'm talking about is logical. Once the VE table is more accurate and O2 Corr is within +\- 5%, I'd add the timing back in.
One question I have with this approach is will the retarted timing have an affect, if any, on the actual a/f? I couldn't see it happening but who knows. I'm out of town so can't take my car out to test any of this out, so I figured I'd post about it and see what you guys think.
I'm also only running 17 psi boost, my combo should be in my signature.
Giancarlo
Giancarlo
