Tta pistons
1fastcobra
Looking for any info on
Tta pistons.
What company makes them besides
J.E.
Id like a c.p. , diamond. Or. Wiseco
Stroker and . Standard
I run the tta head
I have a few sg1 blocks im building for a spares
In the past I just used a GN piston which gives you more choices of pistons to choose from. Compression will be higher, but a long as you are running Alky you should be ok. Spool is better and you don't have to run as much boost for the same power. The difference comes from the chamber. TTA head is roughly 41 cc's versus the 46 cc GN head. You also can use a thicker cometic head gasket if your concerned about the compression. You will love the quicker spool from the higher compression.
JB
