TTA heads lifting?
LSTTYPE
590
43
28
119
Eudora KS
i know this has been discussed before but im farely new to these cars (tta). Im wondering why the tta head lifts at a much lower power level than the GN head? Also is there any remedy ie head studs, cometecs??? Im eventually gonna build my tta for mid 10sec power on e85 so im curious. Thanks in advance
JP112_89
1,028
43
48
Yes they do flex.... If your car is capable off 129-130 mph in 1/4 your at your limit.
Use stock style hg's...think its #9441 and ARP bolts. I'd shoot for high tens and leave it alone.
  • Like
Reactions: Kendall1214
Kendall1214
88
4
8
32
What’s your set up? Idk too much about the (TTA) but I do know some guys have swapped to GN heads but there is also some work to be done to make them work! But as JP 112_89 said! It’d be easiest to back out your goal to high 10s! A 10 second street car is still fast!
  • Like
Reactions: JP112_89
dank GN
BlackArts Automotive (661)993-8277
Jan 11, 2009
3,670
453
83
SoCal the high desert
Slap some head studs on and make sure your head and block are nice and flat . Also if you are concerned about heads lifting then go with some RJC Head gaskets . They also make clamps that will clamp your head down . Truthfully you don’t need to be worried about that till you are making over 500+rwhp+
LSTTYPE
590
43
28
119
Eudora KS
It might end up being pretty quick. Its got a nice 212/212 roller and a 6266. Havent chosen a converter for it yet although I do have a 911 lockup for it if I choose that route. I plan on going through the motor soon because it smokes through the breathers. I plan on porting the heads.
  • Like
Reactions: BEATAV8
JP112_89
1,028
43
48
Definitely get the heads ported but becareful and don't go crazy.. Some people I know hit the water jacket... anyways, nice cam but 6266 is gonna spool slower with with a 9/11 especially if it's a journal bearing turbo and or stock headed.
I would send that converter to PTC and let them guys set it up for you...
A high percentage of us TTA owners do not need the 66 turbine wheel. Smaller 62 will spool faster and make great power. Use if you got it though that's a nice Turbo. You're just going to need more converter.
62 turbo, ported heads, smaller cam and good converter (like you have), turn it up and let the boost do its thing.
LSTTYPE
590
43
28
119
Eudora KS
Thank you for the advice. It so happens that my brother has a 6262 that im sure he would trade me for. I am definitely open to sending the 911 off to PTC or even getting a PTC non lu for it. Thanks again
INEEDAGN
Seen Your Member
Feb 28, 2003
3,816
339
83
119
Northeast Kansas
Visit site
Luke,
What's the stall speed of your 9/11? I have one I bought but haven't installed yet and I figure it's probably too loose for my 44. Might be able to swap converters...
I was told 3000-3200. I'd install and verify before I traded you.
LSTTYPE
590
43
28
119
Eudora KS
Luke,
I had it rebuilt and stalled to 3200. Not sure if I will ever run it. It's just sitting in a box and I'm really liking the ptc in my t-type. Might put a ptc in the tta as well
  • Like
JP112_89
1,028
43
48
Luke,
No, it is not ..it will probably be right on. Probably stalls 24-2600 @ 1# boost...not 3000-3200... guarantee it.
Put it in.
Scott89TTA
1,138
38
48
58
Eldersburg, MD
Once mine is running again I'm looking to defy these TTA wall limits. My new motor is fully built, 0.040 over, Comp 220/220 roller, Ross pistons, K1 rods, Eagle crank, billet mains, all ARP hardware, Champion ported big valve TTA iron heads, Pro Series ARP head bokts, Harland Sharpe roller rockers, Cometic head gaskets, billet PT7168HPQ turbo, FAST Xfi, dual nozzle Alky, 120# injectors, A1000 external pump, TH400 with PTC 3600 converter, etc. Our goal is in the 9's in the 26 psi range...hopefully we will find out this summer.
Kendall1214
88
4
8
32
Nice set up!!!
  • Like
Reactions: Scott89TTA
proptop
132
18
18
Sir,
Contact Fastair6 here on this site he can answer all of your questions on lifting heads on a TTA. He might even have some ported heads and studs left over from his previous builds.
Thanks,
Bob
TT/Ameasap
The White Blur
Jan 31, 2002
4,788
439
83
41
TTA heads are not the way to go for a low 10 sec car. My car was very light and 60' in the 1.4 and at 23psi lifted both heads. Went with TA Eliminator race heads and at 17-18psi the car was just as fast. Ran a few 22-23psi all out runs on the street with no problems. GN head design is better and the TA head is a beast.
Scott,
I wish you luck... I couldn't get it done and I tried about everything.
Kendall1214
88
4
8
32
Scott,
Did you have to modify the car any to put the TA heads on?! That’s what he’s looking to know!
Street Lethal
Tech Anarchist
Oct 8, 2006
2,320
133
63
So you did actually go through with it and sold it. Damn, that was one of the nicest TTA's I've ever seen.
BTW, what's with this infamous TTA wall I keep reading about, is it really that tough seeing 9's in a TTA...?
  • Like
Scott89TTA
1,138
38
48
58
Eldersburg, MD
It's all about the boost/cylinder pressure on a built motor and the TTA heads. A stock motor with bolt-on upgrades you can run the boost up pretty high with a good tune and good ARP head bolts (I ran the Pro Series)...I ran 26psi on 93 and Alky for about 8 years without any issues. But with a built motor and big turbo the cylinder pressure goes up quite a bit and the TTA heads don't like much over 24psi...probably 26psi is about the max above that the heads start to lift. Several have made it to the 600-650whp but always come up a little short of a 9 sec pass...10.1's seem to be about the wall. TTAFAN ran ~10.15 @ 134 with a 1.56 60' 25ish psi and a conservative tune...he was very close but hasn't really pushed it either. Billy Anderson built his engine 10+ years ago and it made 630ish to the wheels, he also built mine basically 10 years later with some better parts, bigger cam, bigger more efficient turbo, a little more cubic in...Billy says it will make more power and be faster. We will see LOL
  • Like
Reactions: Street Lethal
Scott89TTA
1,138
38
48
58
Eldersburg, MD
Top Bottom
