Tsm parts
steve hughes
#1
35 spline Detroit Locker for 9 inch ford rear. Used 6 runs. Includes carrier bearings and races. $400.00 shipped
#2
2 Weld Drag lites 15 x 10 5.5" backspacing. Holes drilled for rim screws.
$300.00 + shipping. Prefer not to ship
#3
Comp billet roller cam 236 236 @ .050 .584 lift 112 lobe center. Nose cut for torrington bearing and adjustable nose bolt retainer setup. Used in good condition. $300.00 shipped
#4
DLS custom ground solid billet roller cam. 224intake 218 ex. @ .050 .577 lift 112 lobe center. Nose cut for Danny Bee cam retainer. Used in good condition. $325.00 shipped
#5
Lower control arms. Mfr. unknown . Trailer tie down loops welded on. No holes for swaybar. Used in good condition. $100.00 shipped
#6
Champion lower intake for stock or off-center . With thermostat and billet water neck. Pcv hole welded shut. Port matched to slightly larger than a felpro 1200 gasket. Used in good shape. $500.00 shipped
#7
Stock intake with adaptor for Champion upper plenum. Pcv hole welded shut. Front right corner has been welded. Does not leak. Ported to 1200 gasked.
Egr passage inside and outside welded shut. I ran 9.28 with this intake on the TSM combo. $250.00 shipped
Most of these parts have went 9.28 on my 109 or 9.27 on the stage motor.
I can do paypal as long as it's not from a credit card.
Go here for pictures parts for sale pictures by 86grandnational - Photobucket
Found some #s on the detroit lock. Engraved in the side of it.
176S160A
22-D-05
Part # on the cam is 67-000-9 BV67/4873S HR112
SN# K5305-07 4-20-07
adv. 273 273
.050 236 236
lobe sep 112
lift .584
I have misplaced the cam card on this . I'm still looking for it.
176S160A
22-D-05
adv. 273 273
.050 236 236
lobe sep 112
lift .584
Steve,
What 9 inch did you have the Locker in?
