Hi Guys. Finally got my new Gen 2 and LC1 wideband installed. Also the TT Extender Extreme G chip. Have a few get started questions. Whats a good starting point on timing? On my old TT 5.6 you adjusted it for 1/2 and 3/4 gears separately. Looks like with the gen 2 its just 1 setting for all gears, but is adjustable through the RPM band. Would you leave the timing the same through the RPM band?
Also, whats a good starting point on the AFR tracking? The car has alky injection, and I see most people in the 10.8-11.2 range on Alky. I'm thinking start around 10.8 a little on the rich side to be safe. What TPS voltage setting would you start tracking at?
I'm sure there are plenty of other questions I will have about this setup, so any advise or recommendations are appreciated. I am going to play with it for a little while, but it will be going to the chassis dyno for some tuning before too long.
