Trans Mount & Saftey Loop
Anyone with Poly Engine Mounts and trans mount have problems with the rear tail shaft of trans being to high for the driveshaft to fit through the safety loop? IE...safety loop will not allow for the driveshaft to be installed!:mad: Thanks Deren
I had to go with a Metco loop after installing poly mounts as my Kirban loop would not clear.
The loop I have is 4.5" wide ID and 5.5"tall ID dimensions. Dont know if that helps but what the hey. Ujoint mount is hitting inner top part of loop.
