Had trans brake issues this summer (electric brake in a 200R4). It wouldn't always hold, it would typically roll a few feet then lock. If I pushed the button a couple times it would usually lock so after checking the wiring I figured it was the solenoid. I replaced the solenoid and same result. But I stumbled on that it seemed to lock better when cold, or if I held the button for a few seconds while in 2nd then pulled it into 1st. I can hear the solenoid clicking which makes me think it's something beyond. I understand that it locks the 1st and Reverse clutches and the solenoid releases Reverse... But could somebody please explain further how the fluid flows? When I changed the solenoid the line and fittings seemed ok, no cuts etc. The transmission is working great otherwise. Ideas?
