TR6 ignition with XFI
gnxtc2
Staff member
Finishing up a new install of a TR6 ignition and XFI 2.05.
On the TR6 box, I have all the switches set to off. The motor doesn't sound right idling.
Checked everything over and everything checked. I got disgusted and had to walk away.
Just wondering if the TR6 needs a different set up due to the XFI.
Billy T.
gnxtc2@aol.com
Don't have the car in front of me to check the switches but alot of us use a xfi and tr6 with no issues
I must be overlooking something stupid.
Billy T.
gnxtc2@aol.com
Did you say "something stupid?
if you are running the coilpack you need to have dip #4 turned on for wastespark mode
hard to tell whether you said you also put 2.05 in
if you just put 2.05 in theres a buncha stuff that has to be checked and changed for that update
mode 4 on and you need the main rev limit switches set to something
check your plug routing
