buickcowboy
- May 26, 2004
I installed total seal rings during my rebuild and am now having oil consumption problems. Does anyone have a solution? I think it's going through the PCV back into the intake manifold. Any suggestions?
Originally posted by buickcowboy
And now for my next experiment, I'm gonna try to trap the oil. I'm thinking take an airtight container and connect it inline in the pcv line. The pcv end should connect about 1/2 or 2/3 the way up on the container and the throttle body end should connect at the top. The oil should collect in the container, right? Then measure collected oil vs. oil usage on the dipstick. I'll post results later.
Originally posted by wnarunm
Ok, no flaming here... but
Back in the day my friend installed the total seal gapless rings in his SBC and that sucker pumped oil. We thought maybe the hone job or some other cylinder problem... but it was definatly ring related. Took them out problem went away. Another friend's brand new motor, this time an LT1 stroker was burning oil bad, and of course he commented on his gapless rings. He later took them out and his problem went away. Now after spending the better part of a year getting certified as a performace engine builder I have learned that the gapless ring design has a flaw.
-any race engine builder will tell you that todays trend is running a substantially larger gap on the second ring and a substaintially tighter gap (ring manufacturers recogmendations can be conservative) on the top ring. The top ring seals primary function is to seal combustion pressures the second rings functions as combustion sealing/heat transfer and oil control. The tighter the second ring = more chances of trapping combustion and fluttring the rings causing CRAZY amounts of oil consuption.
The design of the gapless ring actually causes the top ring to lift and flutter becuase the combustion becomes trapped between the first and second rings. Basically they seal TOO well.
How can you make it work? = gapless top ring and standard bottom ring.
It is true that total seal rings are some of the best made, but no professional racer runs the gapless that i've heard of, they run the standard total seals.
