I thought I had cured my misfire....tooling around tonight with the wife a little bit to show off my skillz fixing the car... A couple of full throttle blasts and no problem...no misfire...17lbs of boost. I stopped at a little station that had VP 108 out of a pump. I put 6 gallons of gas in ...10 minutes later I cracked on it and psi hit 14 and it started flattening out and misfiring just like before.
I figure too much octane maybe so I add 6 gallons of 93 from another pump....should give a mix of abot 100 or so I assume. It is still misfiring. What gives guys....bad gas? Too much octane?
