alphajesse
Hello everyone.
First: sorry to ask a question that probably gets asked often, but the search feature didn't reveal any definitive answers to my question or solutions to the problem.
A friend of mine just got a 1984 Regal T-type. The car is great! You guys are lucky to have them. It has a cold-air type intake with a K&N cone filter, an upgraded turbo of some type, dual 3" exhaust and now it has some skinnies up front and some fat slicks in the back. It is also equipped with a posi rear end, and a TH350 transmission. The body has 140k on it, the engine and trans, 5k. Got a great deal on it.
The car has pretty severe hesitation/stumbling on quick throttle opening- even just to 50-75%. I'm familiar with turbo lag, that's not what we are experiencing. It also doesn't feel like the transmission is slipping. The engine almost feels like it is attempting to stall.
What exactly causes this?
A full tune up is in the immediate works (plugs, wires, clean filter, oil & filter change) but I get the feeling that this won't fix it. The car is fine once it's going, so I don't think it's the coil packs. My personal turbo car (a Mitsu) would fall flat on it's face at higer RPM under boost when the coil was dying.
The threads I found all mentioned that the MAF, the ECM and the coilpacks could be the problem. In my case, which would it most likely be?
How can I narrow the problem to a specific system?
Also, what fixes this?
If it's the coils, new ones of course, but if the MAF or ECM, are they repairable, or must they be replaced? Where is a good source of parts if replacement is required?
Thanks for the help!
