Time for Frame off.
Chuck Leeper
Toxic old bastard
Staff member
Sam, THANKS!
Lost a good bud w/ a jack stand incident. I'm so paranoid, I leave a jack under the car, and pull a stand w/ me, any time I'm under the car.
I have one of those rotos...ONLY way to do a underside!
DSEROVY
Wow - your not fooling around!
I just pulled my car out of (barn) storage - been there for 15 years!
I'm going to begin unbolting everything this weekend to get the frame out , on the hunt for a rotisserie now.
Good luck!
Sam Colalillo
low 9's w/ a 109
Added GNX vent holes to the fenders. The kit from G body came with really nice cutting templates and the vents are great quality.
Also cutting the door bars out before they go off to the body shop.
I had the body wet blasted. appears to be in really good shape. A little work to do and it is ready for epoxy primer.
Hotfoot
do you have close up of the vents? looking for a close to stock set myself, alot of junk
Sam Colalillo
low 9's w/ a 109
Very nice. Question, how do you get that driveshaft out when the body is back on?
Yeah its going to be tuff Mike. This is one of the main reasons i pondered the x brace in the center. The X brace is not necessary for the 25.3 cert when you use the factory door hinge pillars. But if you modify the factory firewall and floor, or use fiberglass doors then the X brace is required. My car will not need the X brace, but i chose to do it just in case i ever opted for lighter doors.
When i studied the driveshaft layouts, in efforts to determining my ride height and pinion angle layouts, i studied whether or not it would come out. The drive shaft does come out, but it takes some work. The car will have to be high in the air, the rear end raised so the driveshaft can slide all the way out the rear of the car.
On another not all the control arm mounting points are not favorable for the instant center of gravity I think I need for the ride height I aiming for. I will get this all corrected.
