This should be easy. The stock bracket that holds the throttle cable and the TV cable is not adjustable at the throttle cable attachment. This means that when the throttle cable stretches, you may lose "full open", and it's hard to fix. (Yeah, you can put washers under the end of the cable under the dash) It would be nice to have a chrome or stainless bracket with slotted mounting holes. That way you could move the bracket to adjust the throttle cable.
