The New Guy From NewZealand
delcowizzid
newzealand turbo 3.8
finished tuning the new turbo today ran out of injector at 19psi well ran out about 17psi but decided to run it leaner than normal just to keep boost up where it used to run.60lb seimens at 98% duty cycle with fueling in the 12's on 19psi seems we gained a heap of flow up top LOL hits full boost at 4000rpm totally no traction now on the street feels a bit soft cause it just cant grab the ground LOL think its physically impossible to street tune it any further LOL
delcowizzid
we run hoosier quicktime pros in a 26x10 and 26x10.5 at the track as low as 12psi in them hot and they were only just holding before the upgrade boost hits hard 0psi to full boost in half a second hopefully they still stick its the last drag meeting this coming weekend then shes being retired from street dutys to become full drag car with full weld in cage and suspension upgrades LOL cant wait to see it run with 90/10's etc fitted it doesnt transfer weight well at the moment no front end rise to speek of LOL
delcowizzid
Yeah but only front and rear weights on the weighbridge was around 60/40 front to rear in its stripped state with driver 2888lbs total
charlief1
RIP Charlie!
You really need to get a 4 wheel scale done. It gives you a much better idea of where the weight is sitting.
delcowizzid
Yeah we just borrowed some and scaled my mate's competition car was 29kg light on the right rear 90kg light on left front made a huge difference snapped the full spool in half 3rd pass after evening it all up lol.will scaling a soft monocock construction car do that much she's pretty old and flexible lol.we have contemplated just fitting a longer spring in the right rear or filling it with tennis balls just to see what happens it kicks the rear left every time so it needs more grip on the right rear for sure.
charlief1
RIP Charlie!
Most don't believe how much just scaling a car can do to understand why it won't hook up. The G body GM chassis has some cute tricks you can do, like adding 100 lbs of weight in the wheel well. This may be why you keep blowing the tires off easily. It may be a simple as adding some weight in the right places to get the tires to hook.
delcowizzid
went back to testing ground definately needs more spring in the right rear leaves a much lighter color line behind the car on that side LOL might double up the swaybar too
Reggie West
TurboBuick.Com Supporter!
That tells you how much the rear end and the body twists from the motor.
The HR parts bar will fix that and it will keep the seams between driver and passenger windows from cracking.
charlief1
RIP Charlie!
Do a little research about the HR bar and it may give you some interesting ideas on how to control the traction issue. You preload it so you can get better traction.
delcowizzid
drags done and dusted low 11's again due to not having time to get it fully spooled and a handbrake that couldnt hold the rears from turning and did a headgasket at 35 odd psi by accident when we had boost controller jamming issue went good to half track with no traction then the gasket went when the map sensor hose popped off must cable tie that one day LOL.ported cast heads going on while its apart and some new manifolds and a flange that actually matches the turbine footprint LOL and 4 inch dump pipe currently using pipe the same size as the exhaust wheel exducer .
delcowizzid
Well after fitting so ported heads with bigger valves that we found and struggling to do low 11s we went back to stock ones.when refitting the springs we checked the pressure 90-100lb not good but we had to run them while waiting for New 145lb ones to arrive.New pb 10.505@129mph 1.56 60 104mph half track
delcowizzid
and the car looks a bit different now gloss black new fibreglass bonnet 6 point roll bar plus race numbers LOL tech inspected to 10 flat also now has mikes transmissions usa ultimate beast transbraked 350
SPOOLFOOL2
Fiberglass bumper filler dude. (949) 433-1257
Staff member
Can you shim the old valve springs to get the seat pressure needed, or will they coil bind?
Glad to hear that you're getting it sorted out.
Happy Spooling.
Mike Barnard
