The infamous "Wiring Diagram" for those who would like it
marleyskater420
still needs to learn
Here is the wiring diagram I received from Kinsler Fuel Injection for wiring my Weldon 2345A fuel pump which flows 220gph@80psi with 14volts. All of the wiring is done with 10gauge copper stranded wire, however you could use 14ga wire for the ignition line only.
If you have any other questions, just ask.
  • Relay wire schematic_10-11-11.pdf
