TES-295 fluid?
77 cruiser
1,277
20
38
Int`l Falls MN
Visit site
Summit had a sale on it recently 117.99 for 4 gals. Mobil Delvac synthetic. Regular price 30.99 gal.
Just put some in my 04 Duramax shifts better & trans seem to run cooler when towing.
SS/GN
2,139
284
83
55
Hard to beat dex6 , Rossler and a few of our guys recommend it and have had good luck. Many opinions on this but in the end its what makes you feel good.
turbo nasty
Turbo Dojo / MNTR
Jul 19, 2001
8,176
409
83
St Paul, MN
Spoke with Lonnie at Extreme auto about DEX 6 a few years back and he explained that DEX 6's patent ran out and the formulation of the fluid isnt what it used to be as companys just make their version .....and he no longer uses or recommends it.
Boost231
What's An Intercooler
Staff member
May 26, 2001
14,721
799
113
35
SoCal
www.arizonagn.com
What does he want us to run in his trans now? I still have stock piles of old DeX 6
turbo nasty
Turbo Dojo / MNTR
Jul 19, 2001
8,176
409
83
St Paul, MN
Just looked at the current file on his site..
Fluid Recommendation Your New transmission will operate on most available transmission fluids. We have our favorites and will list if you choose to use them.
1.) B&M Quick Shift : This is a high quality type F fluid
2.) Redline, Royal Purple and Most Dextron Synthetics work well and have Hi Temp capacity
3.) Dextron 6: Look on the container for Dextron 6
4.) Dex 3, Type F are all fluids that can be used
http://extremeautomatics.com/assets/pdf/2004R_Transmission_Install.pdf
Jerryl
Tall Chinese Guy
Dec 14, 2004
8,052
748
113
Houston, Texas
Disclaimer; I don’t know much about transmission or transmission oil
Attached is a chart I put together of different popular oils used in automatic transmissions. The chart is solely based on “Flash point” and “price”. This ended to be an interesting exercise for sure.
Transmission Oil Comparison Chart
Chart – Sorted by flash point
Top Bottom
