Terminal Strip alternatives?
gnX405
I've got a question about wiring component options that will allow the +5v reference supply voltage to be used for multiple sensors, TPS, MAP, Pressure Transducers, etc.
For each of the sensors there are three leads, +5V, Ground, and Signal.
Are there connectors available that are better suited for grouping multiple wires together than using common terminal strips?
Thanks,
-john
Thanks,
-john
Industrial stuff exists, not really automotive.
...considered euro terminal strips with tie bars?
Thanks. I think those are designed with the intention of being mounted on a bar.
I ended up placing an order for some old fashion terminal strips.
Thanks for the reply.
Here's a pic of the euros , they come in a number of different pitches and lengths.
Using one side to tie every third slot together would do what was required.
