Build list of parts already have:
250ci, all billet caps & girdle
ATR liq intercooler inlet pipe modified to 2.5"
BGC intake
GN1 Alum heads - mild porting
Janis full billet trans
PE 9.5" multi, lockup 40533c
ATR headers ceramic coated
ATR DP
ATR exhaust
rear end girdle
forged axles
HR Stuff full rear suspension kit
FAST nonXFI
Walboro twins
Items to purchase yet:
6466 turbo
214/214 cam
alky - thinking of doing 26 psi
?? injectors
Mega squirt or maybe XFI
Aftermarket drive shaft & yoke to be converted to 1350
So I was talking to my mechanic last night & we had some open questions.
Does anyone think the the twin walboros are enough fuel?
My mechanic believes I should go away from the external waste gate for reliability reasons & concerns that we can't port the turbo hole out big enough to control boost. He is wanting to do a RJC downpipe. I don't see that the 3" dp that they offer is compatible w clearance of ATR headers. Any suggestions here?
The numbers I listed for the converter tells you how loose it should be, should I send it off to be tightened before I put the car back together? What number should I go to?
I have some questions as to if my ATR intercooler will take this much air efficiently. I was planing to add test ports to the inlet & outlet tanks to check the pressure differential, I assume I should have less than 2psi? I've never experienced any intake temp problems on the street that I think people have complained about in the past. My previous build was a 440rwhp motor on pump gas.
This car will be street driven 99% of the time. I'm a type of person that wants to go fast out the light, not do burnouts taking off, so maybe my hp will be limited to that amount or maybe the mega squirt system can do my traction control or it can just reduce the boost n 1st if I add some sensors to the drive train. Also, reliability is tops, as I don't have a truck or trailer.
I assume the combo I have will not be mismatched?
BGC intake
ATR DP
ATR exhaust
rear end girdle
forged axles
FAST nonXFI
Walboro twins
6466 turbo
214/214 cam
?? injectors
