Stock parts and others
wickedsixx
Stock gm 20 bolt timing cover with new neoprene seal and new booster plate and yellow spring. Gears may be new as well. $80 shipped
Water pump and new gasketand pulley bolts installed but not used $25 shipped
Double roller timing chain installed but never fired. $30 shipped
Aftermarket 20/14 bolt cover $35 shipped.
Stock valve cover with factory fasteners $45 shipped
New stainless trans lines...the short ones $25 shipped. SOLD
Trans crossmember with factory fasteners $20 shipped
Water pump pulley and crankshaft pulley with bolts for mounting crankshaft pulley and intercooler fan $55 shipped.
Downpipe bolts and springs $15 shipped.
Side exit exhaust pipe that mounts on your test pipe $50 shipped.
Pics of oil pump cavities/wall where gear face rides on front covers, looking for gouges and wear......thanx
How much for the GM 20 bolt cover?
More info on the Timing Chain set. Brand, p/n, undersized? Billet or cast cam gear?
The casting flash has been removed on the gm cover in the oil passages. I don't have new gaskets for the booster plate so I am not going to take the pump off.
Here are a couple of pics of the aftermarket cover.
