Stock IC and other misc parts
Joel.e
I have the stock intercooler off my project with shroud, brackets, ic fan and up-pipe. All is in good condition except scoop portion of shroud and one bolt hole on passenger side of intercooler either needs tapped or helicoil inserted. Would like $80 plus shipping.
I plan to be at RCG event on Thursday/Friday if that helps.
Also have some other parts from older listings (OBO): (shipping extra)
-test pipe for stock downpipe $20
-3" test pipe w cutout $30
-original ecm with original chip $sold
-original coil pack with replacement ignition module $sold
-stock fuel pressure regulator $10
-stock fuel pump hanger with stock replacement pump from digital dash car $35
Probably other stuff I'm missing but I'll update as I go...
-found a j bracket with heat shield and turbo shield $40 (little surface rust, i can media blast before shipping and you can paint if needed) - SOLD.
Joel.e
Do you have the bolts too?
Had to go look. I have the 1 bolt holding the heat shield on and the 4 bolts that hold the turbo shield that can go with it. Are you sure you don't need the whole thing.
TRICKSIXPA
East Coast Go fast with class club MAGNA!!!
Staff member
Are the heat shield and turbo bracket still available will take them if so.
Joel.e
Feel free to make offers on whats left if you need it. I'll be more flexible if i don't have to ship it.
Also the 3" test pipe does have the 4 bolt flange don't know what I was thinking when i typed it up.
