Great idea for a Fourm
I took my '86 GN today to get tested. I put on a fresh cat and fixed the numerous exhaust leaks and thought it would pass easily. I guess I was over confident.
The Failing numbers were at the low speed (15 mph) 1622 RPM
HC were 193 ppm with passing 152 ppm.
CO was 1.40% while passing is .86%
At the higher speed reading I was just within the limits (148 ppm on a 148 std)
Nox standard was 1146 ppm and I smoked that with a 52.
The two bad things that could have caused the failure was my fuel pressure was 45 psi line off and I had some very small amount of leaded race gas in the tank.
I've turned back the FP to 33 line on (40 line off) and have and I'm going to fill the tank up with gas.
What will help me pass?
