If anyone is interested or has our old style valve, we now have made the valve with a modification that improves oil pressure in low 1 and low2.Valves are 24.99 and will include complete Stage Right instructions so you can convert any set up you have to a Stage Right style brake.
If you want to add the .555 boost valve itll be an extra 11.99. This is a big improvement over the old way of doing it and it improves oil pressure without the use of a larger INT BOOST VALVE to keep the TV BOOST VALVE from being scheduled backwards on brake apply lowering oil pressure.
