SPID label question
T-CHRGD
I’m looking to get a repro of my label done, but it is slightly defaced.
On the bottom of the 87 label is a printed code. On GN’s and WE4’s it is usually U.WA848
On a Limited I have seen a
U.WA8573l.WA8535
On T’s I’ve mostly seen U.WA8574
Mine is a very early 87 and the code looks like U.WA8529
Does anyone else have this code ?
Wow. After all these years, I never put that together. (Actually I only started looking at it now). Mine is a code 79 Dark Red. That’s the only code I ever went by.
Thank You !
Is there any way to get a copy of the sticker using the vin? My sticker is long gone and I would really like to replace it
that's the paint code if they have 2 WA numbers listed then the car was a 2-tone car from the factory if that's the case it should be a D84 designer series and the d84 code would also be on that label
WA 8573 is paint code 15 and WA 8535 is silver paint code 12 that would be a gray and silver two-tone designer series
I’m getting a reproduction sticker from Kirban’s. You must send a picture of your current sticker, however.
