Spark Plug torque spec TA heads
Nick Micale
Tech Advisor
Staff member
What is the recommended spark plug torque spec for a set of TA aluminum heads?
Since the TA head was designed to use plugs with a gasket, generally after the plug makes contact with the head, a 1/8th turn more should seat the plug ok.
turboclam
What's a good plug to use for 93 and alky for the street?
And how about E85?
I have access to both now here in ATL just haven't decided which.
L8TRH8R
Was using the Autolites but Ive now switched to NGK's per Nick. Forget what heat range I went with.
turbo nasty
Turbo Dojo / MNTR
NGK 6466 is a good resistor plug for TA heads its a basic style production plug that works well. A NGK racing non resistor plug non ext reach with cut back ground strap plug is a 5671-7. Some can get away with -8 on the street but may glaze and slight foul with corn.
ijames
I can't find the 6466 on NGK's web site. Can you double check that number, please? Thanks.
turbo nasty
Turbo Dojo / MNTR
14mm, gasket type, 5/8 hex, 3/4 reach, resistor, 7 heat, nickel ground and electrode, v groove.
