TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
OK, was looking for a new project to mess around with and decided on trying some SPAL dual 11" fans for the GN. Running our Super Extreme front mount, working AC, trans cooler mounted between our aluminum radiator and the condensor. Noticed a 10-15 degree increase in temps since going to the FM, no surprise there and have been running the stock fan. Not really an a big issue with temps but wanted to see if I can get back to SLIC temps I had.
I got the SPAL fans off of ebay from a place in Iowa. Good shipping and price. Got the wiring harness with relays from Caspers. Ordered a couple sets of brackets from Summit but like most projects the course changed.
I used the aluminum brackets that go along the top and bottom of the fan units but didn't bother with the ones that go over the radiator core.
Put the GN up on the ramps and removed the stock unit. Do yourself a favor and throw a piece of cardboard against the radiator to prevent any damage to the core.
While looking at the lower stock metal bracket I decided to see if I could get that to work. I knew I would have to offset the fans to the drivers side on the radiator core as the pipe coming off the turbo to the intercooler was going to create clearance problems.
One important thing. The rubber flaps on the top and bottom of the shroud, make sure you have them so they open from the bottom. It is easy to mix up the top and bottom since everything looks the same EXCEPT for how the flaps open.
Bolted the stock lower bracket to the aluminum strap and ended up offsetting the bracket as seen in the pictures. Went thru the larger holes using fender washers on either side. The fans have rubber flaps on the top and bottom I guess this is to allow more air to pass at highway speeds???? These allow you access to the bolts to tighten them later on.
I loosely mounted the fans at the bottom and went up top to see what to do up there. Again, I used the aluminum strap that I bought from Summit but needed to come up with a way to attach things. Decided to make up 3 tabs to connect to the aluminum strap. Mocked everything up and made up 3 brackets that would attach to the fan thru the aluminum strap and then to the top part of the radiator. I made the brackets have a bit of offset to allow enough clearance to the radiator. The bottom bracket supports all the weight and the tabs up top basically just locate the top, not really any stress on them.
I put them on the fan assembly but didn't tighten all the way. Installed the assembly into the car and loosely tightened the lower bolts. Wanted to be able to move things around to make fitting easier once I got to the top tabs.
Now up top, the tabs are bolted on with the head of the bolt pointing towards the radiator core. Used 1 1/4" long 1/4" x 20 stainless bolts with washers and nyloc nuts. Positioned the tabs to the holes I drilled in the radiator top and tightened up the tabs. Then put the bolts thru radiator top. Used 1" long bolts there. Oh yeah, lower inside bolts I used 3/4" long bolts as anything longer lifts the rubber flaps up.
All clearances looked good so now was time to tackle the wiring harness. Decided to run everything down under the fans as I have seen cars done with the harness along the top and didn't like the way it looked. Biggest decision was how to mount the relays. Made a little bracket from aluminum and mounted up top on the passenger side, this allowed enough length for the power lead to reach the battery.
Put the whole unit in and bolted everything up and so far so good. One complaint about the Casper harness though, they want you to replace the positive battery bolt with a longer one they include BUT it won't work with the replacement positive cable they make with the nice cover on it to prevent accidental shorts. Decided to use the original bolt and slit the battery cable end to sneak the eye ring inside it. Cut a little slot in the cap and put it on and worked fine.
Before buttoning everything up I turned on the key and hit my manual fan switch and one fan fired right up, the 2nd fan has a delay so they both don't come on at the same time. 2nd one comes on 5 seconds later. This so a big strain isn't put on your charging system all at once.
Everything is going good at this point so something has to go wrong right? Went to put on my radiator top support cover and something isn't right! The tabs for the AC line brackets is hitting the top of the fans. They should probably should have been mounted about 1/2" lower I guess. I AM running a one-off top cover though so not sure how the stocker will work.
Sure as hell didn't feel like yanking everything back out again so got the old Dremel tool out with a plastic cutting bit and just made a couple of slots for the top cover to sit into, came out perfect. Had to trim off a bit on the bottom of the AC line brackets as well but you can't even see it.
Everything fits and happy with how the install went. Just have to throw my 4" MAF pipe back on and good to go. Supposed to be hot this weekend so should be able to get a good test of the units.
Will post all the pics I took and have to take some more with everything back together later. Hope this helps those who are hesitating to do this mod. Can't guarantee this will work on every intercooler out there but now DO know that it will work with the Super Extreme IC we sell.
ONE OTHER THING! The slide on nut thingys on the factory bracket......the "nut" part should go towards the front of the car, had them on wrong in a couple of the pics. Also, there are two different length bolts on the four used on the stock bracket. Use the shorter ones. These go thru the holes in the lower RADIATOR support into the factory bracket. Was going to drill new holes to center the factory bracket to the fans but the one on the drivers side had the steering box in the way of the drill so ended up going with the way it is seen in the pictures.
