groumoutis
- May 1, 2009
I am not very well versed in transmission to say the least. I have a stock transmission from what I was told when I bought the car. At WOT at the top of 1st right before it hits second it appears to slip and the. Hits second and goes like normal. The odd thing is it doesn't seem to do it every time. The first time it did it I thought I just broke the tires loose and then it did it again the other day and I looked at the speedometer and it didn't raise. While cruising it is fine but doesn't hit second as solid as it always has before.
I am guessing I am going to need to pull the Trans and rebuild it but I am unsure of what all needs to be replaced and beefed up to make the Trans a little stronger. Which rebuild kit to buy or what should I check first. I just built a new garage and I am a little short in my savings account so I'm not looking to send it off or buy the best parts known to man. I don't take the car to the track but I do smash on the throttle occasionally.
