Shaft Rockers, Pistons and Suspension Parts...
jevans
Pics for those who had questions...thanks...
Shaft Rockers have provision for large diameter springs...
Arias Pistons...
4.000" Bore Ring Package .043 .063 3/16" These were used with a 5.960" Rod 252 c.i.
Adrian87
Any info on the springs? Are they lowering springs or drag springs? Looking to lower my car a little and firm up the ride..plan on doing shocks at the same time.
Thanks.
jevans
ATR Coil Springs...
Thanks.
These springs were part of a Suspension Kit that ATR packaged together. The Kit included Coil Springs, Bilstein Shocks, front and rear Sway Bars. The rear Springs are progressive rate wound, they have a comfortable ride while cruising around and firm up under load. The fronts are a heavier wire and wound tighter. The springs help reduce lateral body roll. They should lower the car about an inch from stock.
