Several Items for Sale
Trader history for N2BUICK (2)
N2BUICK
Donations
$100.00
1.Sun Tach vintage 1960"s era transistor type $375
2.GN steering wheel 25507580 no outer leather cover $75
3.Fuel filter replaceable 10 micron filter AN oring fittings Aeromotive brand $75
4.Fram HPK600 large remote mount oil filter housing 4 #12 ORB inlets/outlets $50
5.Brake pedals one power master other vacuum brake type $50ea
6.New Strange master cylinder manual with 1.032 bore $75
7.Gear drive Buick V-6, no crank gear included $100
8.Stock turbo car metal shift gates have 2 $20ea
9.Glove box light/switch assembly $20
10.RJC Biggie oil filter adaptor . New $30
11.Set of front grille springs $20
12.Boost control valve under hood RJC type $40
13.Intercooler inlet plastic screens both nice $40ea
14.Hot wire fuel pump kits. New $40
15.Coil over spacers plates 95338 Specialty Prods. New $20
16.Flaming river battery disconnect $50
17.TRZ billet alum. master cylinder fire wall mount> New $100
18.Moroso catch can #12 fitting, with drain, top filter and mount bracket $50
19.Weldon Fuel pressure regulator A2040 type, turbo, fuel injected application $50
20.New billet TR alum vacuum block off plate with oring seal $30
21.Billet alum TR vacuum distribution block with bolts and gasket $30
22.New billet alum TR vacuum block for VACUUM brakes $40
23.Stock TR vacuum block plastic $20
24.Hood lamp fixture complete nice condition $40
25.Horn ring center gray with tri shield with metal plate $40
26.Horn ring center gray T center screw missing $75
27.V belt new 123999983 GM in sleeve $20
28.Wastegate Turbonetics model New Gen HD 10733 50MM size $375
29.Billet aluminum battery tray Speedway 9166600 $50
30.Felpro ford 9" rear cover gasket summit 2302 $20
31.New copper exhaust gaskets STAGE2 SCE 4572 $30
32.New intake gasket set STAGE 2, SCE 272103 $20
33.New felpro intake gasket set, 1201 $20
34.New felpro 14 bolt oil pan gasket , 1800 $15
35.Bosh injectors,6ea, 160 lbs, #2801508837, older set very little run time $300
36.3D printed dash insert for TR for Holley 6.8 digital display $75
37.GNX grille emblem new, aftermarket $75
38.Holley 3.5 hand held screen NIB $250 pending
39.Holley power supply fits dominator and others #558-405, NIB $60
40.Holley 4l60/80 trans control harness #558-405, NIB $150
41.Holley WB02 sensor Bosch NIB (bag) $150
42.TURBO word for 3rd brake lamp new $10
43.Meziere elec water pump Buick V6 complete. Have option for remote $375
44.Wheel centers 4, plastic w/metal inner retainers Black w/ power 6 center $100
45.New RCI seat belt cam lock out of date $75
46.RCI cam lock seat belts out of date $40
All parts used, other where noted as NEW. Parts do not include shipping or PayPal fees.
Feel free to ask questions or other pics.
chasmat2316
Donations
$25.00
is the gear drive a 3 bolt or 1 bolt mount idler gear also interested in trz master mount
N2BUICK
Donations
$100.00
Here are a few pics of the gear drive and the wheel centers. They do fit T Type rims.
HotAirWH1
Donations
$25.00
14.Hot wire fuel pump kits -
Racetronix list two different Hot Wire Kits:
Fuel Pump Kit RFPK-006-G75 for 84 - 86 1/2
Fuel Pump Kit RFPK-006-G77 for 86 1/2 - 87
[These kits will only work if you're using a standard drop in 255LPH pump for the stock hanger OR a Racetronix 255LPH pump.
If you have a Racetronix 340LPH, 450LPH or 525LPH pump and hanger kit then this will NOT work. You will need the FPWH-076 Heavy Duty Hotwire Harness for those pumps.]
Caspers Hot wire Kit - #102028 for 84 - 87
Not sure which manufacture of Kits you have.
Please clarify.
Thx.
N2BUICK
Donations
$100.00
Please clarify.
Thx.
The hot wire kit have is very much like the Casper unit. They list it for 1984 to 1987 on their site. I would like to know the 1986 mid year difference in a racetronics piece?
Slow91z
Turbobuick.com Helper
Staff member
I'd like to know a little more about the Holley Dash Mount
alwndup
Do you still have #21? (Billet alum TR vacuum distribution block with bolts and gasket $30)
Remove Ads From TurboBuick.Com
Yearly amount needed to remove ads from TurboBuick.Com
Goal
$12,000.00
Received
$2,246.00
