8kllr
- Mar 11, 2022
I'm in process of replacing parts over winter
Was going to go with ta49 but was wondering what wlse would,work BB is an option id look at.
Heres where cars at
Unopened engine
42lb injectors,hot wire,asjustable regulator,home built alky,cold air intake,3" dp,no cat with dump,tt chip set for 21-23lbs which I can get to 19lbs before I get set. On scanmaster thinking I have exhaust leak on crossover will be corrected
Janice built trans,paperwork says 2600 stall,putting pipes 3" on now
Car has seen,flat 12's with et streets and race gas with dump unopened
May go to e85 in 2024 budget limited each year daughter is autistic so priority 1and worth every dime
Thank you for any advice and help
Heres where cars at
Unopened engine
