Curious to see if people think this is about right for using 80 lb injectors of if something is a bit off. Combo is as shown below in sig. On E85 with -8 feed line, -6 return line, stock fuel rail. I'm hitting 98% duty cycle at 21 psi boost around 5300 rpm. Air temp that day at the track was around 75* F. AFR on the gas scale was 11.0-11.2. Base FP set at 43 psi and during the runs it stayed steady at 60 psi. I know it should have been 64, so either the FPR isn't the greatest or the gauge is off. It's a digital unit.
Since the motor is a stroker I realize that at the same boost level it would be using more air than a stock stroke thereby requiring more fuel. However, it's not like it's that many extra cubes. Best et was 11.29 and best mph was 124. Couldn't get a 60' below 1.73 though due to my 255 et streets and terrible track conditions.
What do you all think? Should I try ditching the raw aluminum style FP reg for an Accufab unit or is there something else I should be looking at?
