Seat belt guide
GNRick
Retired member
How long of a screw is needed to attach the seat belt guide to the headrest? What exactly does the screw go into? Thanks.
it needs to stick out of guide about 1 " ,
theres a metal plate inside the foam headrest. if you replaced the headrest covers you can use a pick to locate the holes . if your guide doesnt sit properly you can grab that plate through the foam and bend back into place
