Seal for master cylinder lid rubber gasket
Chris Robertson
Anyone know where I can get a new seal for the LId? 1987 Turbo T. When I pump my breaks with engine off I can hear itt letting air out. Is this normal? I just put all new brakes and fluid in and now it makes a leaking air sound when I slowly pump breaks. Pedal is soft due to leaking I think. No brake light on and pump just rins to prime system and shuts off as normal. Any help please. Thank you, Chris
regan j
Have you checked the local part stores? I do not know if it is different from a standard brake master cylinder cover. Take yours with you and compare. Brake fluid loves water so leave the lid as as shortly as possible.
Chris Robertson
Thanks guys. So I put new hoses and shoes on. Put S10 rear wheel cylinders on. Bleed everything till no air. Now pump runs and doesn't stop. I'm so frustrated.
TurboTGuy
Gray Beard Member
Richard Clark will either have it, or will advise or guide you to the vendor who does. I would bet the farm on it.
