SAFE transmission line HOSE??
HellOnWheels
HellOnWheels
Feb 3, 2002
916
4
18
119
Central USA- Arkansas
centurytel.net
Is there such a thing as a safe/reliable transmission HOSE? I'm a little apprehensive about using high pressure fuel hose as a transmission line. I've installed a trans cooler and don't have access to the tools needed to do a double flare on hard lines.
High pressure hydraulic line appears to be to stiff/thick to use hose clamps!!?
All suggestions appreciated.
Thanks,
HOW
1986 Buick GX1
GX1 #001 [The One and Only]
Apr 24, 2015
1,319
303
83
55
Manly IA
I believe they sell transmission cooler line specific hose but if it's not to your liking or not available the SAE 100R3 hose may fit the bill.
SAE 100R3 is fabric braided medium pressure hydraulic hose that can be tightened with hose clamps. It's related at 1130 working pressure and 4520 burst pressure for the 3/8" size.
https://www.hydraulichose-fittings.com/mediumpressure/sae-100r3-hydraulic-hose.html
I say fabric braid to distinguish it form wire braid.
SAE 100R1 is single wire braid hydraulic hose and SAE 100R2 is dual wire braid hydraulic hose.
I have no idea why they labeled it with the R3.
I installed my trans cooler using the SAE100R3 hose in '87 and hasn't come apart yet.
  • Like
Reactions: HellOnWheels
pacecarta
MAGNA
Staff member
Aug 1, 2003
9,068
747
113
RIP racewaypark, NJ
you should not need to do any double flare to install transmission cooler lines
just disconnect and remove one of the OE couplers by the battery , the oe lines are double flared
slide the line nut back and push hose on over the already flared end and then clamp it
you can get trans cooler specific hose from derale but a good tanscooler kit should include proper hose and clamps
  • Like
TurboTnZ06
Go on red!
May 7, 2002
3,411
240
63
FL
I ran Russell -6 AN nitrous lines that were on sale, couple of AN adapters, AN cooler, replaced all the factory lines. Ran them through the frame out of the way.
  • Like
INEEDAGN
Seen Your Member
Feb 28, 2003
3,787
334
83
119
Northeast Kansas
Visit site
I also used bendable hard line. I've seen good rubber hose fail after 10+ years and I knew my car would be around longer than that. A basic flaring tool is inexpensive (same tool available under many different brand names) and mild steel is easy to double flare with some practice with a harbor freight quality flaring tool. If not steel I'd probably look into oil rated Teflon hose
  • Like
1984 t-type
Murphy's Law
Jul 11, 2010
1,366
68
48
118
Metro Detroit Area
There is a fitting you can Get that screws onto your stock trans lines and has a flare on the end to help hold the rubber hose on. Got mines from Dave Husek when I bought his converter and cooler.
  • Like
dynoman
1,740
333
83
63
Ontario NY , near Rochester NY
The transmission lines going to the cooler have about 50 - 60 psi max trans pressure in them during 1st gear wot launch , and less than that in 2nd & 3rd . I log pressure from the trans to the cooler , so it's not high pressure that you have to worry about .
  • Like
Top Bottom
