I am looking into doing this, but couldn't someone just tighten up the rear brake shoes more than normal to accomplish the same goal....and then simply untighten when done at the track?
I'm curious how the different cylinders help exactly.
NAPA # 46 37644Anyone have a recommended set of part numbers from Napa or whereever?
I've heard that the S-10 cylinders can be kind of scary during a panic stop. Is there a way to remedy this problem? I'm running the longer shoes on my car but haven't installed the S-10 cylinders yet.be very carefull when braking as rear brakes will tend to lock up...EASILY. with big cyl and two long shoes ....BELIEVE ME
Probably the rear tires play a role and are a source of reported variation. I'd think sticky tires would be less likely to lockup in a hard stop.
I just called the dealer and the GM part# is discontinued. So it's either Gbodyparts for the left over GM ones or go with Auto zone. I think I'm just going to order from Gbodyparts because I don't want screw around with inferior brake components.
