RX7 hybrid need help wiring up A/C compressor, and hoses
Turbo V6 231
weekend warrior
if someone can help me I'm in need of some help wiring up the compressor from the buick to the trigger wire from the RX7 using the buick harness and relay for the a/c, I thing the light blue wire coming from the relay is the trigger wire for the buick that is what is given 12 volts to start the compressor , so I would need to figure the wiring on the mazda side and understand which wire triggers the compressor for the original setup, I was told somewhere that the compressor on the rx7 is reversed/ opposite the buick for engaging the clutch, not sure , but if someone can help with this would be a huge help, most of the conversion/ swap guys I have talked to haven't hooked up the a/c, and the only one that did was Misred, and he is nowhere to be found on these sites anymore since he sold off turbobuicks website.
if you have any ideas on this please help, thanks
