Runining a stock 85 block on a Camshaft Kit with a 208/208 Cam?
is that a good cam with stock parts
I am no expert on cams. I had a 206/210 roller cam installed as an isurance policy during an engine tear down due to a blown head gasket. This is with a stock block and all Hot Air. My car runs just fine. Your choice of cam should work just fine. Brad
Make sure the front cam journal has a groove unless your block has one in the cam bore behind the bearing. Only 140 and 109 castings have the groove in the block behind the cam bearing. If its an 85 its likely a 140 but you never know what and who has done what over the years
