Ok question. I have a great tranny, Love it but I have a question on whether I'm doing something wrong or not.
regular driving I don't break the rotor, even at the track I have not broke a rotor.
But this is my 3rd rotor break, the last one only had a hairline crack but was still functional, I just heard a clicking noise around the converter/pump area.
swapped converters it quieted down but still noticeable. Pulled the transmission and the hairline crack on the pump is what I found.
__________________________________________________________________________________________________________________________
The first rotor crack was with an EDGE converter & a completely different pump. (about 300/400 miles on new tranny & pump)(I left the spacers out of the converter/flexplate was the reason & was told to make sure I put them in I did,,, no breaks.
Bought a new 9/11 converter about 4000/5000 miles later...... installed it; again was told I probably didn't need the spacers
1000 miles later (no track times with it) The second rotor crack was with the new and different converter. (7000 miles roughly on pump & tranny since the first break)
The third rotor crack different rotor same pump same converter this time with the spacers .( roughly 400 miles later since the second break)
So my question is am I doing something wrong?????
Could the high transmission pressures be causing this?
The ONE common denominator of all 3 breaks was when I ease into the throttle wide open for like 1/4 or 1/2 mile let off the gas. Once the car coast
coast to a stop no movement (broke rotor). This last time with the hairline crack it didn't break or shatter like the others did, I could still drive
around and even got on it quickly & off to see if I could pin point the clicking/ticking noise & see if it would break the rotor b4 I took it down and apart.
Again I never broke one at the track or cruising only when I've gotten on it & the car shifted in 4th gear. Do you think the 4th gear have something to do with it at WOT & then takes the rotor out on deceleration? That's the only thing I can figure and come up with & IF SO HOW & could someone explain why this would put so much pressure on the rotor at this time.......... SO I'LL KNOW NOT TO DO IT AGAIN. (maybe I need to get on it only in 3rd gear).
