Roller cam selection
Nigel
The only thing that would suck, is if you make enough power to push the RPM in one and two well past the peak and stress everything needlessly.
michael evans
Have you measured for the compression ?
Don't forget to measure for the correct push rods. They will be have to be made for the build most likely.
TireFryer
I have a slow WH-1
I looked over the whole thing, all I saw was 20G, previous owner pained it blue over the original pink.
V6sleeper
It’s a thousand pounds:ROFLMAO: Taking the car to Janice this winter for a stage 1tranny and he’s going to put this converter in the car
Vince is the man, have him verify its the newer 5-disc and not an older 7-disc you dont want to run that one, in all reality you only need a single disc for high 10s on the street, i ran a 5 disc for years with a ta-61 , noisy like crushing pebbles but coupled well for a low 11s car.
