dont use the stock stuff ...just a simple loop from turbo through controller to wastegate
base goes to turbo , adjustable end toward wastegate, dont cover the hole in the adjustable end
use zip ties on all connections
twisting it down will increase boost
make sure you have a good boost gauge and a knock gauge (scanmaster ) and try not to overboost
be aware your boost may go higher once you hit third gear and even higher as you start climbing rpms
