raregn
Addicted to BOOST
- Jul 20, 2010
As the title says, my 200-4R was completely re-built this summer.
It was done locally by a reputable transmission builder, it shifts ok but when I get on it the 2-3 shift is not quite right. 1-2 shift is phenomenal, but there is a flare on the 2-3 shift. Unless I'm driving and put it down causing a downshift, then the 3-2 downshift is great and then I will get rubber in 3rd at WOT.
It has all Red Line clutches and band, all new steels, billet accumulator, Trans-Go stage 2 shift kit, every bushing, bearing and seal has been changed as well. Also using a stock converter that was cut open, cleaned, re-welded and balanced. And I'm sure there is more that I don't remember off the top of my head.
It seems that there is something that is happening when the transmission starts off in 1st that it doesn't really like.
